tv cuts out for a few seconds when the heatings turned on!
johnnythemalt
by johnnythemalt » Mon Oct 29, 2007 12:07 am
tv cuts out for a couple of seconds when the central heating is turned on!
please does any one have any surgestions as to why!!
muttley
tv probs
by muttley » Mon Oct 29, 2007 6:12 pm
try plugging your telly into a different socket and see what happens,the feed to the boiler maybe off the existing telly socket which could be at fault.good luck
by sparx » Mon Oct 29, 2007 8:42 pm
Hi interference from either boiler ignition or more likely room thermostat, more usual if on indoor antenna as signal low and close by, try moving stat up/down to see if you can replicate prob. if so then maybe stat. contacts arcing due to slow action, made worse if no Neutral to stats. 'accelerator' resister. Only other [unlikely] cause is contact of motorised valve if you have one, this will happen a second or 2 after turning room stat up, regards SPARX
It is currently Wed Jan 15, 2025 12:23 am
