Heavy Wall Texture removal
martinofyre
by martinofyre » Mon Oct 29, 2007 11:39 am
A lot of the walls in my 1930 3 bed semi are heavily textured, like roughly spread icing on a cake. Bit difficult to describe but the peaks and troughs are as much as 1/4". Would it be possible to plaster over this? I am thinking you can knock off the peaks and then replaster over.
However I dont want so much plaster the architraves, skirting boards etc dont look silly. Also I am going to strip all the wood in the house and stain if this makes a difference as most of the wood is badly fitted and could do with re fitting after stripping.
I realise stripping off the existing plaster would open up a huge can of worms especially on the lath and plaster walls but I am right at the start of a major renovation so its all getting ruined anyway (rewire, new heating, home network etc.
Advice please.
kbrownie
by kbrownie » Mon Oct 29, 2007 3:19 pm
Hi martinofyre,
If your having rewire and new heating pipework installed, do that first before making bad walls good. What you have on the walls sounds like artex, have a look in the projects section on this site under Artex and plaster removing, that will give you good guidence.
KB
It is currently Wed Nov 27, 2024 5:09 pm
