routing a gas pipe to outside shed.
Aks_72
by Aks_72 » Tue Oct 30, 2007 11:15 pm
Can someone advise I'm thinking of taking a gas supply in to my out building which is attached to my kitchen, from the kitchen gas supply.
It will go as such: From the kitchen through the joining wall into the out building
I will be extending the existing pipe work, fitting a isolting valve and takin it in to the out building. which is a a solid brick pitched slate roof building.
Will i be able to use copper pipe, and are there any rules and reqs to follow[/b]
Bay Plumbing
by Bay Plumbing » Wed Oct 31, 2007 9:44 pm
Aks,
For this i would definaitly get a CORGI engineer in as you will still be breaking the law by installing a gas supply as you need to pass the ccn1 to fit gas carcase and know how to test the extened pipework,please don't attempt to do it yourself.
thanks,
Mark
It is currently Fri Nov 22, 2024 3:25 pm
