Bathroom Spot lights
MattR
by MattR » Wed Oct 31, 2007 12:14 am
Hi, recently moved into our new house and there are 5 small neat chrome spots in the bathroom. I have seen them for sale in B&Q so are probably very common. They have a transformer which is mounted in the loft. When i switch the lights on, they take approx 7-10 seconds to come on. The wiring appears fine and can't figure out why they are taking so long to come on. Once you flick the switch, after a few seconds they are dimly lit then gradually get brighter and brighter then all of a sudden they come on full brightness.
What does the transformer do? What can be done to make the lights come on instantly?
Matt
BLAKEY1963
Re: Bathroom Spot lights
by BLAKEY1963 » Wed Oct 31, 2007 9:07 am
[quote="MattR"]Hi, recently moved into our new house and there are 5 small neat chrome spots in the bathroom. I have seen them for sale in B&Q so are probably very common. They have a transformer which is mounted in the loft. When i switch the lights on, they take approx 7-10 seconds to come on. The wiring appears fine and can't figure out why they are taking so long to come on. Once you flick the switch, after a few seconds they are dimly lit then gradually get brighter and brighter then all of a sudden they come on full brightness.
MattR
transformer should allow lighting to come on instantly , normaly
assuming all connections r correctly fixed.
light sets come in 3 as well. is there a possability there r too many
lamps on this transformer.
the VA RATING , of transnformer , eg can be 150 VA , allowing
3 x 50 watt lamps to be used.
u could check , rating of transformer and condition of connections.
isolate mains first !
IF connections r sound and tranformer rating correct for total
wattage of lamps , then the only thing left is the actual transformer
and as these r sealed units , they r not maintainable .
LASTLY your transformer provides a step down voltage from
mains low voltage 240 v -- a extra low voltage on the output
of the transformer for example 12 volts.
BLAKEY1963
Matt[/quote]
MattR
by MattR » Wed Oct 31, 2007 12:14 pm
In the kitchen we have a set of 3 spots and these come on instantly and these have a transformer. The transformer appears correct for the 5 lamps and connections looks good. The 5 original bulbs are 20watt each and they take about 3 seconds to come on. They don’t provide that much brightness. I would like to put 35-watt bulbs in but I assume this would put too much strain on the transformer?
Does it sound like a faulty transformer because it takes a few seconds for the 5 x 20watt lights to come on?
If so, can you buy more powerful transformers in places like B & Q??
Many thanks
Matt
It is currently Thu Sep 19, 2024 11:30 am
