Problems with storage heaters
lindap
by lindap » Fri Nov 02, 2007 1:15 pm
I have just moved into a flat with storage heaters and one of them has stopped working. I have taken the top off as advised by sparx but there is not a trip switch inside. (It was covered by accident).
I assume that the fuse needs replacing somewhere. Would this be in the rcd unit? I would be grateful for any feedback. The storage heater is a Dimplex installed around 2001.
kuzz
by kuzz » Sat Nov 03, 2007 4:12 pm
The thermal link has gone on the inside of the storage heater. covering it would not blow a fuse. sounds like you were given the correct advice last time. Look harder for the thermal re-set! It is in there at the top by the control knobs. you'll know when you've got it. It'll click back in.
lindap
by lindap » Sun Nov 04, 2007 8:53 am
Thanks kuzz,
I will have another look and let you know!
linda
lindap
by lindap » Sun Nov 04, 2007 9:08 am
Hello kuzz,
I have had a look and found the switch (I think) which has clicked back in!
Obliged for you advice.
Linda.
cobrastang
by cobrastang » Mon Nov 19, 2007 6:04 pm
Same problem here with a dimplex as well.i took the top of and located a little pin behind the switch and got a little click,will wait and see if it heats up now. :?
It is currently Wed Jan 15, 2025 10:26 am
