fitting a towel warmer
johnf
by johnf » Fri Nov 02, 2007 9:08 pm
Can anyone please tell me if I need to drain the entire central heating system of water to fit a towel warmer.
I want to take out an existing radiator and swap it for one of these new chrome towel warmers, but I presume that I will need to drain first.
Hopefully there is a quicker way !
Thank you !
bobplum
by bobplum » Sat Nov 03, 2007 6:47 pm
if you are able just to swap like for like then you should be able to turn down the valves on either side of the radiator but this would be a slim possibilty
you would need to drain the system to allow for the new pipe work to be installed etc
It is currently Thu Dec 26, 2024 1:11 am
