patterned wallpaper
littlebird
patterned wallpaper
by littlebird » Sat Nov 03, 2007 11:55 am
Hi all - new to this forum - can anyone give me some advice on patterned
wallpaper please - Does a large pattern make high walls appear higher? or
does it appear to lower it? if you see what i mean - thank you :roll:
budasbeli
by budasbeli » Wed Nov 14, 2007 11:33 am
don't know if this is too scientific - more a hunch - a large pattern should make the wall smaller, a smaller pattern make it larger. If you want to make the wall look higher use the frock principle - vertical lines give height, horizontal lines give width. Good luck.
It is currently Fri Nov 22, 2024 5:59 pm
