old pine parquet flooring
stew
by stew » Sat Nov 03, 2007 8:47 pm
I have a lot of old pine parquet flooring i am in the process of cleaning off the old bitchum, useing a blow lamp very effective and quick i can tell you
which adhesive will i need to stick them down on to vinal tiles,
you dont get it all off but 90% of it.
pablo2
by pablo2 » Sat Nov 10, 2007 3:07 pm
Hi stew
You will need to remove the vynil tiles first , use a chisel to get under them or an sds drill with a wide chisel if they are stubborn try a hot air gun . As for the adhesive try F.W. Ball there web site should give you several options depending on the size and the enviroment.
Pablo
stew
by stew » Sun Nov 11, 2007 7:41 am
thanks for that i am in the process of removing the tiles and lucky they are comeing up quite well.
It is currently Fri Nov 22, 2024 4:51 pm
