2-way light switch in bedroom
alanr
by alanr » Sun Nov 04, 2007 11:44 am
I am replacing a pull-switch over the bed (the main switch is by the door)
There are two wires from the ceiling into the pull switch - one with black red & earth, the other a single red.
The new fitting has earth plus three connections - L1, L2 and Com-L
Which takes which wires please?
Alanr
kuzz
by kuzz » Sun Nov 04, 2007 2:57 pm
The twin cable go in l1 & l2 makes no difference which way. The singe in to the common.
by sparx » Sun Nov 04, 2007 9:06 pm
Hi very old wiring method but most likely single red to Com. red& blk to L1 & L2, if in doubt look in wall switch. it should look similar, it is Live in to Com, 2 'strappers between switches & sw.Line to light from pull sw,
regards SPARX
It is currently Wed Jan 15, 2025 5:16 am
