rcd testing
8 posts   •   Page 1 of 1
g1zoy
rcd testing
by g1zoy » Tue Nov 06, 2007 6:47 pm
Hello I am new to this forum my question is this I work for an electrical retailer fitting electric cookers, although I have no formal electical qualification I am allowed to do this as I have trained to do so.Now the company want us to test RCDs (trip time and current) am I allowed to do this or do I have to have a formal qualification?
sparks
by sparks » Wed Nov 07, 2007 6:05 pm
To carry out testing you need at least 16th edition wiring regulations ,you need to be nic eca approved or have your work tested by the council any work within a kitchen has to be submitted to the local council under part p of the building regs,you are connecting to a circuit and not plugging it in realisticly .you need to test the complete circuit to ensure it has an earth if you connect up a cooker to a circuit how do you know it has an earth ,!!!!!!!!!!!!!!!!! there are an awful lot of houses that dont have RCD's main bonding to water gas and oil plus all the supplimentary bonding required is essencial and has to be installed get yourself trained wiring regs and inspection and testing ,regs change next year ,if you have no formal qualification training you should not be testing
g1zoy
by g1zoy » Wed Nov 07, 2007 6:51 pm
Hi Sparks and thanks for answering my question. At present we actually carry out 4 tests test1 earth loop impedance,test2 earth continuity test3 cooker insulation and then a final earthloop impedance test all using FLUKE 1652 test equipment.
by sparx » Wed Nov 07, 2007 7:49 pm
Hi, G1zoy, is that a ham callsign?
from G6nlz, Mac qthr.
not going to get in a discussion with SparKs over this one as could go on a bit
regards SparX
g1zoy
by g1zoy » Wed Nov 07, 2007 8:28 pm
Certainly is although not active on the airwaves use echlink now and then
kuzz
by kuzz » Wed Nov 07, 2007 10:01 pm
Anyone can use an rcd tester. No law against that, But if your not competent Your results or recommendations mean nothing!
g1zoy
by g1zoy » Thu Nov 08, 2007 9:02 pm
KUZZ how do you define competant? a person who holds 16th edition regs or someone who has been shown how to do it. I am a competant gas engineer because I am CORGI registered but I am only deemed competant in the categories of work on my card.
kuzz
by kuzz » Thu Nov 08, 2007 11:54 pm
As far as part p goes "A competent person is someone / a company who is approved by one of the government authorised bodies, otherwise known as a Part P Scheme Provider." However connecting a electric cooker up to an existing cooker point is NOT notifiable work. No need for certificates. But the regs say if you carry out electrical work it must be tested, so testing is still necessary.
As far as BS 7671 (the regs) is concerned competent is not clearly defined by qualifications/experience. If someone got hurt it would be up to a court to look at the level of your experience & the quality/relevance of your training. Then if you were deemed competent you would be prosecuted.
That's how I interpret it anyway. And to answer you original question If you have the right training, even if you have no formal qualifications i see no reason you shouldn't carry out an r.c.d test.
It is currently Sun Nov 24, 2024 11:55 am
