Plumbing
JimJam
Plumbing
by JimJam » Thu Nov 08, 2007 3:06 pm
I have downloaded and read your advice on how to clear an air lock in a hot water system. BUT, does anyone know where I can obtain hose with a 20cm. internal diameter to carry out this process.
JimJam[color=red][/color]
bobplum
by bobplum » Fri Nov 09, 2007 7:09 am
20 cm or 20mm 20 cm seems large for a hose
JimJam
by JimJam » Fri Nov 09, 2007 2:27 pm
To Bob Plum. Sorry got my sizes wrong its 20 mm dia.not 20cm.
JimJam
JimJam
by JimJam » Mon Nov 12, 2007 4:40 pm
Where can I purchase a hose toconnect to 20mm taps to clear an airlock in the hot water system
JimJam :?:
bobplum
by bobplum » Mon Nov 12, 2007 7:55 pm
from what i can guess are you going to force cold water thru the hot water system if so any hose will do just use a jubilee clip to tighten or if you a have a mono tap ie in the kitchen put your hand over the outlet turn open the hot tap first then the cold on full power ,hand over the outlet and this may work
It is currently Sat Nov 16, 2024 10:37 pm
