Drains - wire mesh covers
7 posts   •   Page 1 of 1
bornlivelife
by bornlivelife » Fri Nov 09, 2007 12:52 pm
Is it posisble to fit wire meshes over drains (underground ) to stop rats entering the houses (or rat flaps) ?
bornlivelife
by bornlivelife » Sun Nov 11, 2007 6:51 pm
seems this forum has no experts - i posted 3 questions that should be easy for a professional, no replies at all to speak of
thedoctor
by thedoctor » Sun Nov 11, 2007 7:11 pm
There should be no openings underground for rats to get into. If you mean can you fit mesh over a opening in a manhole, the answer is no. If you have an open ended pipe underground there is something wrong with your sytem. The only place a soil pipe sistem should ventilate to open air is 900mm above the highest window.
You accuse the forumof having no experts to solve your rat problem and state this should be an easy problem for a builder. It is not and as correctly stated above there are at least 100 ways a determined rat can get into a building if it wants to including, in our own experience, chewing through a live electric cable to get access to the void it filled. The only answer but one you choose to ignore, is a pest control officer who will eliminate the present rats and any future infestations. There is absolutely no such thing as a rat proof house and they must have chosen your house for a reason so give the pest control officer a chance to find out why.
bornlivelife
by bornlivelife » Sun Nov 11, 2007 9:32 pm
Thanks for your reply, i think my question wasnt clear though as you havent answered it, so i try again
{The question is not about manhole covers (i said underground pipes), the easy question to answer is not the rat problem but the specific question eg see next paragrapgh where i try to clarify, pest controllers know nothing about building i dont think as have tried several}
Question again in more detail:
If it helps to clarify, the open-ended pipe is under a manhole cover like a normal drain 1/2 metre down - there are 2 pipes merging
into 1 there, and sorry if it wasnt clear, my question is can i fit any kind of flap or wire mesh over these 2 merging pipes?
(the rats are going are in the drains, the person who built the extension moved the drains and apperas to have forgotten to block the old ones which are under the extension and must have opened up a hole into caity walls.)
thedoctor
by thedoctor » Sun Nov 11, 2007 9:37 pm
You cannot obstruct the flow in a manhole with anything as stated in the first answer. You cannot fit mesh over an opening in a manhole
bornlivelife
by bornlivelife » Sun Nov 11, 2007 9:42 pm
thank you - sorry for misunderstanding
peter the plumber
by peter the plumber » Sat Nov 24, 2007 2:01 pm
There a simple answer to this one, its no.
If you put meshes in a drain it’s going to act has a filter and block.
There would be not way of removing the blockage with out digging up the section.
I do remember seeing an iron flap in a manhole some years ago on a farm, it was on outlet of the pipe going into the manhole.
It had jam up and was backing up, they use welding torch to cut it off and it was never replaced.
It is currently Mon Nov 25, 2024 3:08 pm
