Railings on a flat roof
Signe
by Signe » Fri Nov 09, 2007 5:40 pm
I have a flat roof with no wall around the edge, so there is a sheer drop of the edge.
Is it possible to fit railings to the walls that support the roof rather than having to drill through the roof and causing issues with water leaking through?
kbrownie
by kbrownie » Wed Nov 21, 2007 5:27 pm
Hi, simply answer is yes! I can not recommend any as I have never used them, but they are on the market.
Good Luck
KB
GRPNERD
by GRPNERD » Tue Jan 01, 2008 5:29 pm
If you said what your roof was made of it would help alot, come back with details and in the meantime DONT go too close to the edge becase you could have a nasty fall and you might not be found for several weeks.
Regards
[color=darkred][/color] :shock:
It is currently Tue Dec 03, 2024 12:20 pm
