Bubble gasket
jeddy
Bubble gasket
by jeddy » Fri Nov 09, 2007 6:02 pm
I need some replacement bubble gasket for my windows but am having trouble identifying exactly which one I need - is there a comprehensive list of these with dimensions anywhere I can compare mine against please?
there doesn't seem to be one with the same dimensions as mine.
(Mine is little more than a simple circle (approx 6mm diam) with an arrow at the bottom (approx 3.5mm wide - R6064X is similar and would probably do but I'm not sure I could push the arrow into the slot.)
Any recommendations for suppliers would also be much welcome.
(I have found one supplier locally however I have a feeling that at £3 p/m I'm being taken for a ride!)
It is currently Fri Nov 22, 2024 6:04 pm
