Help! Which Gas Fire?
cheesebreville
by cheesebreville » Sat Nov 10, 2007 1:27 pm
I have a chimney with a lovely flue that draws really well.
However the opening is only 30cm wide and 60cm high. I have no clue which type of fire to get and I'm finding it really hard to get a straight answer out of fireplace retailers. I want a fire to fit the opening they keep quoting for sorting the opening for the fire. What sort of fires should I be looking at to minimize fuss and cost?
M
by htg engineer » Sat Nov 10, 2007 8:25 pm
It's quite a small place to try and fit a fire, you'll probably struggle to get a inset gas fire of that size. You should be able to get a gas fire with closure plate that will fit an opening of that size.
It's hard to instruct on a fire that you could/should install because everyone has different tastes. You can get fires that look old fashioned or ultra modern.
Try typing in Valor gas fires into google which will give you a good selection. And are all good fires. If you download or view the installation instruction it'll tell you the minimum and maximum catchment space opening this should help you choose.
It is currently Thu Dec 12, 2024 2:36 am
