water not hot enough
paulharris
by paulharris » Sun Apr 01, 2007 7:29 pm
Recently had new bath,taps,shower installed, fed by dual pump.
Hot water to bath isn't hot enough and is very aireated,by the time bath is filled water not hot enough. Water from shower fine.
Two taps,one to turn on bath,shower,hand held attchment. second tap temp control set to max,
Any suggestions welcome
peter the plumber
by peter the plumber » Mon Apr 02, 2007 12:16 pm
They have fitted a thermostatic mixing valves on your taps.
The factory pre set them at about 43C
Noting you can do, its a legal req.
But there could be a flaut, so cheak the water temp or call your plumber back in .
paulharris
by paulharris » Tue Apr 03, 2007 9:39 am
Thanks for the advice "pete the plumber"
It is currently Fri Nov 15, 2024 11:21 pm
