Bathroom basin pipes on show
Jean Ferrie
by Jean Ferrie » Sun Nov 11, 2007 9:43 am
Hi, I've just had a new bathroom fitted and the pipes for the wash hand basin are the first thing you see, because the basin is side on to the door. The pedestal is too far forward to hide them. Is there anything I can do about this?
marrtin
by marrtin » Tue Nov 13, 2007 8:28 pm
All I can suggest apart from moving the pipes, is to box them in. In the past I have used white plastic soffit board which looks the same as a bath or shower tray.
dodgepott
by dodgepott » Fri Mar 14, 2008 9:51 pm
yeah what you can do if the ped allows is to run the pipes in flexible plastic pipe and connect on to the taps with flexi tap connecters same with the waste use mc alpine flexi waste. pipes run inside the pedistool.
It is currently Fri Nov 22, 2024 3:57 pm
