black stains on windows
gulpy10
by gulpy10 » Sun Nov 11, 2007 1:52 pm
We got some windows/doors which keep turning black. It's idigbo wood coated with sikkens cetol hls which contains a fungicide
see below for images
http://privatewww.*******.ac.uk/~colbi/windows.htm
How can the discolourisation be prevented?
pablo2
by pablo2 » Mon Nov 12, 2007 9:15 pm
hello Gulpy
It may be a reaction to the stain I havn't heard of this wood but that would be unlikely, it may be the nails used to secure the beads , copper , steel or zinc have differing effects on deiffent woods , I would guess though if the staining is mainly on the horizontal beads it is from water ingress . Quite often these beads are put on with putty on a roll , this tends to stick to the glass but not the bead in addition it may be badly trimmed . check carefully to see if there is any crack between the putty and the bead . If you have no joy here try phoning Sikkens technical help and ask them .
Good luck Pablo
It is currently Fri Nov 22, 2024 4:59 pm
