wall doctor paper
what2do
wall doctor paper
by what2do » Tue Nov 13, 2007 7:53 pm
Basically I have a large hall and stair with the dreaded wood chip that has been painted many times over the last 30 years. To make matters worst the walls are lattice plaster and if I attempt to remove the wood chip the walls will then basically require being plastered.
Therefore has anyone used Graham & Brown 13130 Wall Doctor Wood chip Cover or similar?
I don’t expect it to be 100% perfect but at the same time I don’t want waste money if it is absolutely useless.
Any assistance is appreciated.
ndp decoratoring services
by ndp decoratoring services » Thu Dec 13, 2007 11:32 am
wall dr is excellent for covering woodchip i've used several times for same problem.
easy to put up, 1 thing tho don't try match the pattern it looks better random, leave it to dry out for a couple of days before painting.
nige.
It is currently Tue Nov 26, 2024 9:12 am
