Floor tiling up to carpet
DIY-mikey
by DIY-mikey » Wed Nov 14, 2007 1:23 pm
I'm taking up part of a carpet and replacing with floor tiles. The part of the carpet that I'm not taking up will meet the floor tiles at one edge - about 1 metre length.
What is the best way to do this so that the finished job shows the carpet and floor tiles meeting tidily?
Presumably I need one of those metal strips for the job?
What's the best way to cut the carpet in a straight line and what should I use to cut it?
In order should I do things here? Di I cut the carpet first, then lay the joining strip and refit the carpet that is staying put, and then do the tiling up to the metal strip?
Any tips for this would be welcome.
marrtin
by marrtin » Wed Nov 14, 2007 11:03 pm
Tile first - its easier to cut carpet than tiles. When finished, using a sharp utility knife, and using the edge of the tiles as a guide, cut the carpet to length.
You can get a special carpet to tile trim (ts called Z or zig zag see Screwfix.com item code 41130) from many DIY shops. but they usually only do one for across doorways, so if you need one longer, you may need to go to a specialist tile shop.
Cut to length and fit. Using a scraper, ram the carpet into the strip.
Sorry, can't post URL's don't seem to work properly!
kbrownie
by kbrownie » Wed Nov 14, 2007 11:37 pm
HI DIY-mikey,
busy weekend for you!
Carpet cut with sharp stanley knife, measure your cut and get straight edge to line up your cut with, i.e. good straight length of wood or spirt level.
Do need carpet/tile trim you can get these at floor and diy stores.
I'd lay carpet back down fitting up to trim, then you have a good starting or finishing point to lay tiles, with fixed trim as your guide. You can take carpet back up then if needs be, no real rules on this one. It's whatever makes best sense for cuts and appearance.
Best of luck
KB
It is currently Sat Nov 23, 2024 11:12 am
