Hoses to fit 20mm taps to connect cold supply to hot supply
JimJam
by JimJam » Wed Nov 14, 2007 3:15 pm
Anyone know of a supplier of 20mm internal dia. I wish to try the method illustrated in Diy Doctor.
JiomJam
marrtin
by marrtin » Thu Nov 15, 2007 10:39 pm
Try using a washing machine hose.
by htg engineer » Fri Nov 16, 2007 8:56 pm
is this to clear an airlock ?
if it is then normal garden hose will do, hold on hot tap with tap open, then open cold tap and hold onto that too.
You need to have a good grip and cover most of the tap outlet.
Should only take about 30secs to back fill
It is currently Sat Nov 16, 2024 10:19 pm
