fitting waste to a belfast sink
doubledrat
by doubledrat » Wed Nov 14, 2007 6:20 pm
hi there
tried fitting my waste to belfast (butler's) sink, but it leaks, so I must have got it wrong!
I had
threaded waste
2x spongy foam looking washers
1 nut for threaded waste
I arranged like this (from top down)
waste
washer
boss green
sink
boss green
washer
nut
should I have used silicone instead of boss green? or boss white instead?
not sure what I did wrong.
because the bottom of the belfast is rough and unfinished, I obviously have to do something special.
any pointers gratefully received!
ta
by htg engineer » Thu Nov 15, 2007 6:27 pm
I would try using putty, this should form a watertight seal.
bobplum
by bobplum » Thu Nov 15, 2007 8:34 pm
plumbers mate would be what i would use
were the threaded section comes thru the sink i would fill with plumbers mate
i would normally dispense with the top washer and use plumbers mate or silicone
marrtin
by marrtin » Thu Nov 15, 2007 10:35 pm
I always use clear silicone. The rubber ring can seal between the nut and underside of the sink, but doesn't stop seepage through the threads.
Many basin wastes don't use a washer underneath so silicone the porcelain and the first 1/4" of waste thread showing and tighten up. Then smear the excess round to create a perfect seal.
Works every time.
It is currently Mon Nov 25, 2024 4:28 pm
