tiling on wood floor -damp proof membrane beneath plywood?
piggles123
by piggles123 » Wed Nov 14, 2007 10:17 pm
we have recently pulled up some old laminate flooring in our kitchen and found that there had clearly been a flood of some sort because there was a large area of blackness and dry rot. we've had a preservation firm in to treat the area and also replace some worn out floor boards. i now need to lay plywood down and tile the floor.
my questions are -
a) what thickness of plywood should i lay down to ensure that no movement occurs beneath the tiles? should i screw or nail the plywood? and how far between each nail/screw?
b) should i lay a damp proof / waterproof membrane beneath the plywood to avoid any further damage from flooding via washine machine etc?
canny
by canny » Tue Nov 20, 2007 9:09 pm
Use at least 18mm WBP plywood, screwed every 150mm.
A membrane would be of no use as the screws would puncture it.The WBP is any exterior ply which is water proofed.
Also use a flexable adhesive when laying the tiles and use water proof grout. Silicone the edges and this will then make the surface waterproof. :)
It is currently Sat Jan 04, 2025 4:59 am
