cold water supply
janeboz
cold water supply
by janeboz » Thu Nov 15, 2007 4:26 pm
why would the bath cold water tap suddenly stop emitting water? Has the pipe under the bath burst?
bobplum
by bobplum » Thu Nov 15, 2007 8:48 pm
i dont want to ask the obvious but do you have a flood of water,if no then you have answered your own question
were does the water come from is it a tank in the loft? check the tank is it full or empty? is the tap working could be the insert,tap head turning but not turning the insert
any work been carried out in the house regarding water?
by htg engineer » Thu Nov 15, 2007 10:10 pm
If it had burst I think you'd know, as you'd hear alot of water and your house may be flooded (if a concrete floor).
It could be a blockage of some sort - the washer may have came away from the tap spindle. or the tap spindle may have snapped. Get a plumber or someone competent to strip tap down and investigate further.
It is currently Mon Dec 02, 2024 8:00 pm
