cooker sockets
pageantcd
cooker sockets
by pageantcd » Mon Apr 02, 2007 8:05 pm
Can I house a cooker socket for an induction hob and oven,in a base unit or does it have to be on the wall nearby.
by sparx » Tue Apr 03, 2007 8:35 pm
regs only say 'readily accessable' BUT would you want to go into the base unit under a chip pan fire to isolate hob? which is why the cooker panel should not be placed behind the cooker/hob
pageantcd
by pageantcd » Thu Apr 05, 2007 10:07 am
[quote="sparx"]regs only say 'readily accessable' BUT would you want to go into the base unit under a chip pan fire to isolate hob? which is why the cooker panel should not be placed behind the cooker/hob[/quote]
Thanks Sparx, I will be putting it on the wall nearby.
It is currently Mon Nov 25, 2024 10:01 pm
