Protective Multiple Earth (PME) ?
PaulS
by PaulS » Fri Nov 16, 2007 1:51 pm
A simple question, but no doubt a complex answer. How can you tell if you house has PME ???
by sparx » Sun Nov 18, 2007 5:42 pm
Hi Pauls,
easy PME (TN-C-S) has main Earth cable connected to side of companies cut-out, along side the Neutral tail,
TN-S will connect to cable sheath with clamp below cut-out,
TT will have a rod outside, so only 3 choices!
regards SPARX
It is currently Wed Jan 15, 2025 10:20 am
