help with light fitting
neil mac
by neil mac » Fri Nov 16, 2007 4:08 pm
hope someone can point me in the right direction.ive fitted a new light fitting in bedroom,i know its wired correctly,but i dont seem to be getting any power.ive lost the power in the other bedrooms,but bathroom and stair lights are working ok.would appreciate any help.
kbrownie
by kbrownie » Sun Nov 18, 2007 6:01 pm
Hi neil mac,
If your sure you have wired correctly, must have loose terminal check all wires are secure in terminals, other than that re-check cables are correctly in terminal blocks. It sounds like your live supply from previous fitting Stairs/bathroom is not connected right that's why no power to your bedrooms as they will be the next in the wiring circuit.
Some good diagrams explaining loop in method in the doctors projects under lighting and switches.
Best of Luck
KB
It is currently Wed Jan 15, 2025 10:22 am
