Hello
There are so many problems that can arise, perhaps someone has met this one.
I have a gravity system -old boiler Ideal Standard 80K BTU with micro bore, pumped, two manifolds, 11 rads of differing sizes. But one in the study 'stopped' getting warm some time ago. The sytem seemed well balanced before then. I have drained syetem, which always had fernox in, added new inhibitor. the cool rad drained fine, no sludge.
The water is hot at the inlet of rad - but not at outlet. It will just not go through the rad, I have even put a new rad on. Althought it is microbore- I replaced the in/out valves for normal valves each side of rad so that thermostatic valves could be fitted.
So all the house is fine , but one room refuses to heat up. It is probably the furthest away from the manifold. Could the return pipe be blocked?, would that be strange? no other rads are affected. I have turned down lockshileds on other rad dramatically. still no go
Frustrating- any thought much appreciated Thanks
