Leaking hot water cylinder
Duncan Walls
by Duncan Walls » Tue Apr 03, 2007 2:05 pm
We get a small leak from around our hot water cylinder when the power to it is switched off. I am not sure if the leak is coming from the cylinder or the pipes supplying hot water to the house. There isn't a leak when the cylinder is turned on.
Grateful for any ideas on what could cause this.
stuart_craigon2003
by stuart_craigon2003 » Wed May 28, 2008 12:19 am
I'm not sure what could be causing this but if it’s your cylinder it HAS to go. A leaking cylinder is anything but good. You might like to try getting in touch with an excellent cylinder manufacture in Scotland:
McDonald Engineers (UK) Ltd
Flemington Road
Queensway Industrial Estate
Glenrothes
Fife
KY7 5QF
Tel: (01592) 611123
They will be able to give you all the advice you need and their good at it too!
Stuart
rosebery
by rosebery » Wed May 28, 2008 12:28 am
You need to trace exactly where the leak is coming from.
If its from the cylinder then it's a new cylinder I'm afraid. If so and your system isn't fully pumped then current regs say that must be upgraded as well when fitting a new cylinder.
If it's from the pipework then that's probably an easier situation to deal with - but you must trace it.
Dave From Leeds
by Dave From Leeds » Fri May 30, 2008 12:57 am
Some years ago I had a leak from the seam around the top of my hot water cylinder. Managed to stop it using Plastic Padding's Chemical Metal product. However the leak returned after about a year and I had to change the cylinder. What you say about the leak stopping when the system is switched on suggests that the leak may be on a joint in the pipework, maybe one of the cylinder connections. As others have said, you need to find out where the leak is.
It is currently Sat Jan 25, 2025 4:52 am
