Non reversible TRVs
danblue
Non reversible TRVs
by danblue » Mon Nov 19, 2007 11:30 am
Can anyone help? i've discovered that (along with two other 'reversible' TRVs fitted to the ruturn) my plumber has fitted a Drayton TR4 on the return. I am pretty sure this TRV is non-reversible.
Does this really matter? Am I going to damage the system by leaving it? It's a pressuried system. I've left the TRV on a high-ish setting so I suppose it's acting like a locksheild.
Thanks for any words of wisdom.
Dan
peter the plumber
by peter the plumber » Fri Nov 23, 2007 10:14 am
Well you should fit trv’s on the return pipe for the simple reason that hot water pipes could affect the temp sensor on the trv.
But I wouldn’t worry about it.
The system will be ok and work.
I can’t see it causing any problems; your trv may turn off before the right temp, so just turn it up a bit to fix it.
It is currently Mon Sep 30, 2024 2:56 am
