by stevenc1603 »
Mon Nov 19, 2007 11:26 pm
I would say your looking at a big job. You will more than likely need a part p registered sparky to do the electrical work.
The amount of work will depend on the type of wall. If its proper plaster it would need to be chased for the cables to run in. If its plasterboard, its slightly easier, although both would require repair afterwards.
Might be easier to have the room re-sheeted over the top of the existing cabling, although you would lose a small amount of the room doing so.
