CROSS BONDING
6 posts   •   Page 1 of 1
MICK101
CROSS BONDING
by MICK101 » Tue Nov 20, 2007 8:20 pm
HI JUST FITTED A ELECTRIC SHOWER.FOR CROSS BONDING DO I NEED TO RUN THE 4 MM EARTH CABLE BACK TO THE CONSUMER UNIT EARTHING TERMINAL.
Kristof
by Kristof » Wed Nov 21, 2007 11:02 pm
You don't have to, but make sure your supplementary bonding is continuous, radiator, buthtub, copper pipes, Electric shaver socket, any exposed conductive parts have to be bonded
MICK101
by MICK101 » Thu Nov 22, 2007 7:20 am
CHEERS KRISTOF SO DO I NEED TO FINISH OFF BY CONNECTING THE 4 MM EARTH TO THE EARTH TERMINAL ON THE 45 AMP SWITCH ?
thedoctor
by thedoctor » Thu Nov 22, 2007 7:30 am
See our projects section and look at the project called earth bonding.
kbrownie
by kbrownie » Thu Nov 22, 2007 11:00 am
Hi MICK101,
Becasuse electrical shower should be on a circiut independant to it's self, earth does need to be terminate back the fuse/mcb at CU.
Regards
KB
Kristof
by Kristof » Fri Nov 23, 2007 9:43 am
MICK101,
you have to run a short lengh of 4mm cable from copper pipe (using earth clamps) suppling water to electric shower and terminate at the el. shower's earth terminal. Keep the bonding continuous, from there (copper pipe) to buthtub, radiator, any exposed conductive parts
It is currently Sun Nov 24, 2024 10:48 am
