Loose Plaster Boards
Patrick Cross
by Patrick Cross » Wed Nov 21, 2007 9:13 am
I'm decorating a bedroom at the moment. When I removed the old wall paper I found a staright line crack running the whole height of the interior plasterborad wall. The crack is about 3mm wide and appears to be the joint between two pasterboards - one side of the crack is sitting proud of the other and I can push it back (if that makes sense) and it looks as if the fixing from the plasterboard to the beeze block wall has failed.
Any ideas on how to fix this please? I guess I can't just fill the crack as the movement of the loose plasterboard will just dislodge it. Any thoughts much appreciated.
kbrownie
by kbrownie » Wed Nov 21, 2007 10:50 am
hi,
your right the board is not bonded to wall, i'd make a few holes in board big enough to put some board adhesive a long this joint and anywhere where it is loose. so it bonds and sets
then repair holes and tape the joint and fill out.
regards kb
It is currently Fri Nov 22, 2024 9:28 pm
