Frost on Decking
Gumpy
Frost on Decking
by Gumpy » Wed Nov 21, 2007 2:20 pm
Any advice on how to cure decking with frost on it please
silvergb
by silvergb » Wed Nov 21, 2007 3:57 pm
Why not try cutting up pieces of sandpaper and glueing them upside down on the decking. This would provide a non-slip surface and if different colour sandpaper were used would also look very pretty. Hope this helps.
3magnet
Re: Frost on Decking
by 3magnet » Mon Nov 26, 2007 4:07 pm
[quote="Gumpy"]Any advice on how to cure decking with frost on it please[/quote]
To find a cure you have to have preventative measures in place. Frost happens when condensation freezes. The only way the reduce the frost on your decking, is to either cover the decking with a tarpaulin at night and lift it in the morning, or do as what contractors do to car park areas at shopping malls i.e. gritting the deck with course salt. This might not be the ideal solution, as salt is bad for plants. The third option I can suggest is to pour warm water onto the decking in the morning before you want to use it.
Hope this helps.
GrahamBennett
by GrahamBennett » Thu Jan 31, 2008 3:32 pm
Have you thought about tacking chicken wire to the decking?
It is currently Fri Nov 22, 2024 11:36 am
