Slow flow from taps
colinb
Slow flow from taps
by colinb » Wed Nov 21, 2007 7:40 pm
Hi all, my first post. I have a problem with my taps. The other day i found that the flow from my downstairs COLD tap was slow, usually it is strong/normal. Now i have discovered the same problem from the upstairs HOT tap in the bathroom. Very slow. All other taps are fine. Someone suggested i change the washers?
Any ideas please?
Thanks colin
peter the plumber
by peter the plumber » Thu Nov 22, 2007 3:37 pm
Get a cheap pair of taps for about £15 and pop them on the downstairs sink.
See what thats like.
I think this just a case of an tap jaming up with time.
I am sure its not your water supply.
colinb
by colinb » Fri Nov 23, 2007 7:21 pm
Thanks Peter. I will give it a try and let you know. Colin
It is currently Fri Dec 27, 2024 1:58 am
