Single brick out house using Plasterboard
clematised
by clematised » Sat Nov 24, 2007 1:36 am
I am changing use of the single brick outhouse which is attached to the side of the house for a utility room.
Most of it I have tiled but there is an enclosed toilet which I will tile the lower walls and wish to add plaster board to the top half so how do I do it.
I bought plaster nails but my son says I have to dot and dab the boards to the walls and he says I need to buy ready mixed plaster and add water
Is this correct as I will use wallpaper and would hate it to go black with mildew
Edna
kbrownie
by kbrownie » Sun Nov 25, 2007 10:45 pm
HI clematised,
Yes you best dot'n'dab but use wall board adhesive, not diluted ready mixed plaster to stick to walls.
Regards
KB
clematised
by clematised » Tue Nov 27, 2007 1:03 am
Thanks KB will do as you say
Edna
It is currently Wed Nov 27, 2024 4:54 pm
