CLEANING SANDSTONE
rothwellio
CLEANING SANDSTONE
by rothwellio » Wed Apr 04, 2007 1:45 pm
[/b]Please can anyone help with the best way to clean a sandstone fireplace.CHEERS mark :D
thedoctor
by thedoctor » Mon Apr 23, 2007 7:23 pm
What are you cleaning from it. If its paint go to our paint stripping project, if its just dirty scrub with a scrubbing brush and some slightly soapy water.
doubletrouble
sandstone cleaning
by doubletrouble » Wed Apr 25, 2007 1:44 pm
Hi, I have several sandstone internal walls to pick, point and clean, any idea's on how best to clean large areas, they have old plaster on them and just years of dirt! Thanks
flapper
by flapper » Sat Mar 22, 2008 7:52 am
needle gun and compressor, needle gun has a pistol with a holder for pins which scuttle around when air passes over them, which you hold against the stonework, comes up a treat
the joints can be raked out using a point tooled pistol also with compressor,
dont use a steel wire brush you will make the stone black
It is currently Fri Jan 03, 2025 4:03 am
