No hot water from white meter heating system
tpholmes
by tpholmes » Sat Nov 24, 2007 9:39 pm
Just moved into new house, white meter storage heating seems to be working apart form not being able to get hot water. The only way to get hot water is to use the booster which is proving to costly. I have set economy 7 timer to the correct time (winter) and timed setting also turned thermostat up from 70 degrees to 80 degrees but still have to boost for hot water. Any help would be most appreciated.
BLAKEY1963
by BLAKEY1963 » Mon Nov 26, 2007 8:50 am
tpholmes
the off peak side to the hot water tank needs checking.
get in an electrician.
BLAKEY1963
tpholmes
by tpholmes » Tue Nov 27, 2007 8:48 pm
cheers
It is currently Sun Jan 19, 2025 3:29 am
