painting newish walls ? Lines show up ?
andy007
by andy007 » Tue Nov 27, 2007 5:48 am
[b][color=darkblue][/color][size=18][/size]hi, I have a house that is 4 years old with light emulsion paint on the walls. i painted some rooms and they have three coats of light colour paint over this, you can see the cutting in lines, even with the three coats. We use candles in the front rooms and i can only think these are making black marks in the new paint going on ? Any ideas before i paint the hallway ?[/b]
pablo2
by pablo2 » Thu Nov 29, 2007 9:20 pm
Hello Andy
Not sure if I understand your problem but if it is the cutting in you are able to see , then this would be normal as it is a different texture to a roller ,try cutting in first then rollering as close as you can to ceilings walls sockets etc. some paints such as silk show this up more than others .
Pablo
andy007
by andy007 » Fri Nov 30, 2007 7:35 am
I will try that, i was going to mix 1 to 4 pva and water, paint that 1st ?
It is currently Fri Nov 22, 2024 5:20 pm
