fitting a track type spotlight with halogen bulbs
kevin1956
by kevin1956 » Thu Apr 05, 2007 3:13 pm
Iam having problems wiring a new track spotlight, the lights remain on even when switched off.I have connected the 3 black wires to nuetral, connected the live switch wire to live and connected the other 2 red wires to each other.Could the plastic dimmer be a problem?
by sparx » Thu Apr 05, 2007 5:19 pm
disconnect 1 wire at dimmer does light go off ?
if so then switch must be prob. if stays on the connections are wrong!
see Project wiring a ceiling light & treat your track light as if it were the flexes of a pendant
It is currently Thu Dec 12, 2024 6:46 am
