plumbing
pdlochrie
plumbing
by pdlochrie » Tue Nov 27, 2007 2:26 pm
does a triton t80i have a filter and if so how do i clean it as the pressures never been the same since recent water board activities . i think it silted up
cheers
peter the plumber
by peter the plumber » Wed Nov 28, 2007 5:54 pm
Depends on how old it is.
The spares diagram for the Triton T80i shows a cartridge/flag assembly, but it’s telling me “item obsoleteâ€
marrtin
by marrtin » Wed Nov 28, 2007 11:07 pm
Most of the Triton showers have a strainer built in to the short inlet pipe where the water supply connects to the inlet valve.
Unfortunately this filter is not accessible without disconnecting the water supply first. Often, the only way to do this is to remove the unit from the wall, turn upside down and look into the inlet.
Of course, this means disconnecting the power supply which should ONLY be attempted by a competent person. Please give serious consideration to this point!
It is currently Sat Nov 16, 2024 6:16 pm
