Water Tank
djdigitald
Water Tank
by djdigitald » Thu Nov 29, 2007 11:30 am
Hi there, i currently have a problem with only a trickle of water going into the water tank in the loft thus only the Mains fed tap in the Kitchen working! I had to turn the mains tap off the other day as i had a small leak under the sink which has been rectified, would the turning off of the tap caused the problem or could it be more like the valve in the ballcock has given up?
bobplum
by bobplum » Thu Nov 29, 2007 5:29 pm
hi i wouldtake a trip into the loft and investigate the ball cock
did you drain the system when repairing the leak if so ballcock may be jammed
bob
It is currently Fri Dec 27, 2024 3:31 am
