Install Ceramic sink
Hammo
by Hammo » Thu Nov 29, 2007 7:47 pm
I am fitting a ceramic kitchen sink. Instructions say centre punch hole then cover with masking tape and drill 8mm hole. then gently tap with centre punch to the required size, sounds easy. Do`es any one have any advice as to making sure I do not crack the glaze or worse still the sink . Also how would I fasten the sink as there are no fixings supplied with the sink. Would be grateful for any advice. Hammo
peter the plumber
by peter the plumber » Fri Nov 30, 2007 11:06 am
We use a tile drill bit for these, its much safer to use than a masonry bit.
Just get one the right size to start with and don’t hit the centre punch too hard.
Like most kitchen sinks, you need to cut a hole for them, we use sealant to hold them in place.
You first use your sealant on the underside to the sink, then when it’s cured a bit, go round the top rim edge of the sink.
The sink shouldn’t move once the waste and water pipes are in place.
Hammo
by Hammo » Sat Dec 01, 2007 3:44 pm
Thanks Peter will do as you say
hammo.
It is currently Sat Nov 16, 2024 8:40 pm
