tricky bath panels
lynneoliver
tricky bath panels
by lynneoliver » Thu Apr 05, 2007 9:53 pm
We have a problem with our plumbing under the bath and we are completely unable to remove the side panel off the bath. Is this normal or are we being feeble females?
peter the plumber
by peter the plumber » Fri Apr 06, 2007 1:14 pm
What kind of panel is it?
Make sure you have a good look for any screw that could be holding it in place.
If it’s a thin plastic one, you can just pull down on it and pop it off.
There should be a bit of wood a long the bottom off it too, remove it.
If it’s a wooden one, it could be screw in place.
It is currently Fri Nov 15, 2024 9:01 pm
