torbeck cistern valve
7 posts   •   Page 1 of 1
normanwilmotfreeth
by normanwilmotfreeth » Fri Nov 30, 2007 5:32 pm
I have had one of the ubove fitted in a toilet
and it runs how do i stop it
peter the plumber
by peter the plumber » Fri Nov 30, 2007 10:38 pm
The float has jammed
Or is set to the wrong height
Lift off the lid on your toilet and adjust the float height until the water stops running.
normanwilmotfreeth
by normanwilmotfreeth » Sat Dec 01, 2007 4:54 pm
thanks but tried no help the float submerges under the water.. even if i lift the arm the water still runs the valve dose not seem to close.befor when i first took it apart to clean i heard a clunk as it shut off never done again
norman
peter the plumber
by peter the plumber » Sat Dec 01, 2007 6:29 pm
replace it with a new one
bobplum
by bobplum » Sun Dec 02, 2007 5:15 pm
can i just ask did you buy it from bq this as happened a few times to me all with new ones from that store
normanwilmotfreeth
torbeck valve
by normanwilmotfreeth » Mon Dec 03, 2007 6:40 pm
yes it was B Q
bobplum
by bobplum » Mon Dec 03, 2007 7:00 pm
say no more
id replace with a decent one from a plumbers supliers
It is currently Fri Dec 27, 2024 1:44 am
