Heat Proofing Plaster Walls
Ask questions and find answers on a range of subjects relating to self build projects
amcdon4117
by amcdon4117 » Wed Dec 05, 2007 12:45 pm
I have a pair of woodburners that are begining to damage (cracking plaster) the plaster walls (plaster on plasterboard) closeby. Can anyone advise on the best methods of replacing these surfaces (fitting flush with surrounding plasterwork) with a material that would be heat proof and paintable?
alexx
Vitcas Heatproof Plaster
by alexx » Wed Nov 26, 2008 1:59 pm
You can buy Vitcas Heat Resistant Plaster and Vitcas Heatproof Screed and other high quality Refractory Materials like Premium Fire Cement directly from manufacturer in Bristol or you can Google "vitcas.com" or "firecement.co.uk"
TheDoctor5
by TheDoctor5 » Wed Jan 28, 2009 10:33 am
It is currently Fri Nov 22, 2024 12:26 pm
