Extending water supply (cold feed) to new out house
narmi
by narmi » Wed Dec 05, 2007 1:23 pm
Hi there, I'm all new to this so please accept my apologies for any wrong doings.
I have has a new out house built at the bottom of my garden and wish to take a cold water feed there. I need to know what type of piping to use and at what depth the pipe needs to be in the garden. The feed will come from my kithchen through my extension (also new build & floor has not been finished yet) & then through the garden.
Your help is much appreciated.
narmi
[/b]
peter the plumber
by peter the plumber » Wed Dec 05, 2007 3:56 pm
It’s easy to do, its just backbreaking work.
You need to use “blue polyethylene pipesâ€
narmi
mdpe poly pipe
by narmi » Mon Dec 10, 2007 12:58 pm
Thanks for that,
I was wondering, can I use 20 MM as this would be easier to reduce to 15mm copper or is it as easy to reduce 25mm to 15mm.
I am also confused with male & female connectors(dont laugh) :lol:
Pleas shed some light on this
Thanks once again
Narmi[/b]
peter the plumber
by peter the plumber » Tue Dec 11, 2007 3:44 pm
They do make a 25mm to 15mm MDPE copper adaptor and there about £7 from screwfix. Go there on this link
http://www.awin1.com/pclick.php?p=14407 ... 071&m=1228
You can’t use 20mm, I know its easier, water regs say 25mm MDPE so that’s what you have to use.
Male and female parts……….
The only time you have to worry about these parts is if you are using an adaptor.
Say your putting your connect 25mm mdpe to ¾ steal pipe.
The male part is normally the end you insert, the female is the receiver.
narmi
by narmi » Wed Dec 12, 2007 12:50 pm
[b] :D Thanks for that.
Great help
Narmi[/b][/b]
It is currently Fri Dec 27, 2024 6:41 pm
