In the dark with light fittings !
Rayo
by Rayo » Wed Dec 05, 2007 4:01 pm
Hopefully there is an electricity boffin out there who can help with what to you might seem as an easy problem to solve. Unfortunately it's got me baffled.
I recently tried replacing 2 wall lights and a ceiling light.
When I removed the old ceiling light I thought I had grouped the wires together in exactly the same way.
There were 3 cables connected to the old fitting but unfortunately I'm not now sure if I have them grouped together correctly as the light won't work.
2 cables have 1 BLACK, 1 RED and the other has 2 REDS. All 3 cables have another wire that doesn't have a sleeve but they have been grouped together using GREEN insulating tape.
The 2 REDS and 2 BLACKS are connected together. The other 2 REDS are seperate from the others but are also grouped together.
The wall lights are seemingly straightforward to reconnect. There are only 3 wires; RED, BLACK ,GREEN/YELLOW (E,L,N ) So deciphering where each goes on the new light fitting appears simple Red = Brown, Black = Blue and Green = Green. However they won't work either.
At the moment none of the new fittings are in place as none work.
HELP!!
thedoctor
by thedoctor » Wed Dec 05, 2007 6:11 pm
This question has been asked over 80 times in 3 months. Please do what is advised and visit our projects section where, in the many electrical projects there, the answer is demonstrated safely.
by sparx » Wed Dec 05, 2007 10:01 pm
Hi as DOC says this is all too familiar a post, however yours is interesting as wall lights don't appear to be connected to centre light so should work on own switches?
Centre light : The cable with the twin reds in is from your switch, one red should go with other 2 reds in spare term. block [not connected to light fitting], the 2 black[neutrals] should go to Neutral of light[blue], the remaining red from twin red should go to Live of fitting [Brown].
look at project' ceiling rose wiring for pictures,
regards SPARX
BLAKEY1963
by BLAKEY1963 » Wed Dec 05, 2007 11:39 pm
RAYO
get a sparky in to check things over.
BLAKEY1963
Rayo
by Rayo » Thu Dec 06, 2007 1:13 am
Thanks for your help lads.
It is currently Mon Nov 25, 2024 4:33 pm
