by 333rocky333 »
Thu Dec 06, 2007 7:02 pm
I see an earth rod is a bit of a problem then,do you know if there is an earthing terminal or bar,where the main fuse supply enters the building.
Any bonds would be better going to that temporary, rather than a water pipe or having none at the sockets.
Not sure about france but our earths would be run with or within in the cable for each circuit, and its not acceptable to use an earth from another circuit, when inside this cable the earth core is never larger than the live cores ,so you may need some wiring done to conform.
Are you sure there is no earth, in some countries, sometimes sockets look two pin but have a metal earth tag which connects to the plug when inserted.
I would get someone qualified in france ,as if your freind has used water pipe ,it may possibly be ok to do this in france, or he may be putting the whole block at risk.
