2 way light switch wiring problem
starbear
by starbear » Thu Dec 06, 2007 5:15 pm
A self imposed problem because I failed to note the connections before removing a two way switch. It may be further complicated because one of the 2 switches is a two gang wich operates an external light.
The set up is in the hallway and consists of:
[b]switch X is a 2 gang switch [/b]with two cables routing to it; a) 3 core RED/ YELLOW/ BLUE and EARTH and b) 3 core RED/ YELLOW/ BLUE (no apparent earth but may have been chopped back)his pair of switches is meant to operate an external light (one way)and an internal hallway light (two way)
[b]switch Y is a 1 gang switch [/b]with one cable 3 core RED/ YELLOW/ BLUE and EARTH
This switch is meant to operate the same hall light (2 way).
The two gang switches' cables have one RED and one BLUE wire from each cable joined and insulated (not connected to switches at all) leaving YELLOW and BLUE in one cable and RED and YELLOW in the other (apart from earth). A short jumper wire was used to connect the live red between gangs (switches)
New switches seem to have L1;L2 and L3 terminals now, is L1 always the same as common or another way is the single terminal always the common?
Can anyone please advise where the remaining wires should go to all switches. I think I have tried every combination without and it all worked just fine before I interfered.
All help gratefully recieved.
thedoctor
by thedoctor » Thu Dec 06, 2007 8:20 pm
See the projects section on two way switching
starbear
by starbear » Thu Dec 06, 2007 10:38 pm
If I could have found the answer in projects I would have done so but thank you for your reply nonetheless.
It is currently Wed Jan 15, 2025 4:22 pm
